Software for Checking the Temperature on CPU
Latest computer with Intel core duo processors and computers which have thermal sensors can measure the temperature of the CPU.
In addition you can download hardware monitoring software for check the CPU temperature status.
Go to https://www.cpuid.com/softwares/hwmonitor.html and download the latest release of HWmonitor (version 1.21).
Run the setup file and install it to your computer then run the software.
You can find out your computer hardware status through this software.
Core Temp and SpeedFan are the favorite software check CPU temperature status.
Thank You,
John Major.
There are free applications on the internet even Windows gadgets that can display CPU temperature readings on your screen. One example of such software is CPUID HWMonitor. It is a free hardware monitoring application that reads PC systems main health sensors like voltages, fans speed, and temperatures. The software handles the most common sensor chips such as ITE IT87 series, the majority of Winbond ICs, and more.
Added to that, it is also capable of reading modern CPUs on-die core thermal sensors including hard drive temperatures through the S.M.A.R.T. feature and video card GPU temperature. The program provides one setup file or installer for both x86 and x64 operating systems. Another tool that will allow you to see the temperature of your processor is with a Windows gadget called All CPU Meter by AddGadgets.com.
This gadget allows you to display on your screen the temperature readings of your processor cores including the amount of free and used RAM and virtual memory or page file. Unfortunately, the gadget will require you to install a third-party program called “PC Meter” so the gadget can display the temperature readings. I’m currently using it right now and it is completely safe.
I scanned it with ESET Smart Security. PC Meter is included in the download page.
