anupp
Posted on - 10/09/2011
I have heard of having features like Battery care function in some Sony notebook which sets the charge level. This would help to avoid the charging if the Battery if it's fully charged. Is there any software is available which will provide this kind of feature for other notebook ?
lee hung
75 points
Software to control the battery charge level for a notebook.
It depends on the Notebook model . Some manufacturers e.g. Acer, Dell , Lenovo has their laptops pre-installed with battery monitoring softwares that tend to intelligently manage the battery consumption based on usage of the PC. As for setting the charge level, I'm assuming that you meant preventing overcharging the battery once it is full. Li-ion batteries which are in use in most notebook devices have a built in mechanism for preventing over charging.
Hello Anupp,
Most of the manufacturers nowadays provide their own battery monitoring software with the laptop. There exists plenty of external 3rd party software as well. “Laptop Battery Monitor” is one of the best. You can have it from this CNET link.
It accurately provides the exact discharging time of your laptop battery. The software runs with very low memory and a shortcut is also placed on the system tray.
