I would like to install a software on my PC that would monitor temperature of all components on my PC, adjust the fan spin rate, improve FPS and shut any unnecessary programs. Which is the best software and from where can it be downloaded?
Software to control temperature of components
Hello Frank,
Perhaps you should try using SpeedFan to track your PC’s component temperature. It will help you to find the cause why your PC hangs during under heavy load or long usage. And you will be able to control your fan speed. Try to visit their site to download SpeedFan. And to improve your FPS, I think it depends on your GPU and internet connection speed.
I hope this information will help you.
Martine Paul
