Software to convert exe to jpg photo
Hi there,
I primarily work on mac's with Photoshop in mind. But that is when I am at work, I work on windows Photoshop at my home pc. I have noticed that I have accidentally exported a graphics file into an ext file as opposed to a jpg file.
I don't think Photoshop has the ability to save an imported ext file to jpg format.
I was wondering if there was a software that could convert an ext to jpg photo.
Thank you.
Answered By 0 points N/A #168684
Try to change the extension of the file from ext to jpeg or png and see if that does the trick
You should also try to change the file back to the Photoshop extension and then try to save it as Jpeg or Png.
There are Software’s available that do exactly the same task as you have mentioned.
Please check the list below:
1. NewOCR Online Converter just uploads your ext and get converted jpeg.
2. Convert your PSD files to jpeg.
3. Easy to convert PSD to JPEG.
HTH!
