Software to convert a jpg to line art for Mac
I have some pictures in JPG format and I want to convert them in to line art in my Mac. Therefore, I would appreciate if someone could tell about the software programs available that would convert a JPG to line art for Mac. If possible, please give some more details on how to do the task as well.
Best Answer by jesdegar
Answered By 0 points N/A #149285
You can use Inkscape at: https://inkscape.org/en/
Step:
1. Install x11 first if you're running 10.4 in the system below.
2. Install Inkscape into your computer.
3. From menu file -> open select picture you want to convert.
4. From Menu -> path and trace.
5. In "trace bitmap" click "Update".
6. Click "OK".
7. If you want adjust the result, just click "Edit" and click undo to see Previous picture.
8. Finally save your picture in .eps
Answered By 0 points N/A #149286
Download a copy of Inkscape, from Google search.
1.   Install Inkscape on the computer. Mac users with systems older than 10.4 may need to install X11
3.   Open the conversion tool. From the main menu, select "Path" and "Trace Bitmap."
4.   Click on the "Update" button in the "Trace Bitmap" box.
