I need a good software to convert aac audio to wav file. I used to use total video converter but it is very slow and the quality of music degrades a bit. Is there another software that can do the conversion quickly and effectively?
Software converting aac audio to wav quickly
Converting aac to wav file takes a while before to be converted but I can give you some link where you can download the converter. It is the best way to make things easy especially to those people with deadlines and works to meet. And make sure that the software that you are going to download and install in your computer is compatible with your operating system that you are currently using. Also do the updates especially the recommended once for security reasons.
https://sourceforge.net/projects/lamexp/
http://www.brothersoft.com/downloads/aac-to-wav.html
Hello Hannah,
You can use iTunes to convert acc audio to wav perfectly, as long as you have got the file there. iTunes is free, and if you know the exact format of the audio files, in this case it aac, it is very simple;
The following is the procedure you will need to use to convert the aac audio files to WAV using iTunes:
With iTunes open, you will need to go to Edit, and then choose Preferences.
After that you will select the Advanced tab.
And then go under "Import Using", and then select "WAV Encoder"
After that click OK to leave preferences
In the Music library, you will need to right-click the tune, and then select "Convert Selection to WAV". iTunes will create the WAV file, and that is it for the conversion.
Carl
Some freeware software lets you convert aac file to wav file quickly. Xilisoft is software which enables you to convert your aac file to wav easily. Such as MP3 WAV OGG MPA MP2 AU AIF, etc.,
It allows you to extract audio from many video formats to WAV file, such as MPEG WMV ASF DAT VCD SVCD DIVX XVID, etc.
Not only those, WMA to WAV Converter can convert or extract any part of audio from your media file. It also has the preview function.
You can go to
http://download.cnet.com/PeonySoft-AAC-Converter/3000-2140_4-10911509.html?
It’s a trial version. You can check this out.
