lorie
Posted on - 12/12/2011
Can you please suggest on what software can I use to convert MS Excel files to PDF files? I tried to use one program but I’m not contented with the results. Please send me some suggestions and links where I can download it. Thank you.
Software for Converting Excel to PDF Files
Hi, I have really easy solution for you. I was getting tired to find this software a few years ago. Finally I got some useful links. Now I am going to share these links. Hope I could help you.
https://www.pdftoexcelonline.com/
I know this site very well for a long time. They are giving trial version for 14 days to test it. You can do a lot of works within this days with this software. This is really amazing and unique software ever I saw.
I have another link to share with you they are giving 15 days trial version of their software to test a lot. This software convert XML files to PDF very easily. In this link you can see the tutorials, how to use their software. Hers it is-
http://www.clicktoconvert.com
I think you find your software. If you want this software for professional use, please buy this and it will work better for you. I can recommend you the first link, because they are giving discounts.
You can print PDF file from any software you are using that allow print command by using a simple software called PDF creator.
To download PDF creator use link:
After installing this software whenever you press Ctrl+P or you open print dialog box a new printer is there with the name PDF creator. Select it and click on print it will automatically print the document, page etc. in PDF file without any trouble.
