Kyle Berry 30 points N/APosted on - 11/17/2012
How to convert xls to txt mac? I am having a hard time of seeking some software for mac operating system that can possibly convert xls to txt. I know you have some idea about mac operating system compatibility measurements. I need some advice.
If you want to convert a Microsoft Office Excel file into a text file, you don’t really need to convert because you can do it right within Microsoft Office Excel itself by saving the file into TXT format (.txt). Start Microsoft Office Excel then load your worksheet file.
Once the file is loaded, click on the “Office” button and select “Save As” or press ALT + F + A on your keyboard to bring up the save as dialog. In the save as dialog, in “Save as type,” scroll down and select either “Text (Tab delimited) (*.txt)” or “Unicode Text (*.txt)”.
Microsoft Office Excel save as text
Save the file and that’s it. Your Microsoft Office Excel worksheet is now in text format.
I’m not a tech geek. I don’t keep up with every new gadget launch. I fly a few times a year, watch many movies on my phone, and live in a small apartment where...
With 2025 just around the corner, it is time to start thinking about what tech trends will be coming our way. Tech moves at a rapid pace. Some things may pop up next year...
1....
