Software could not be installed
I reformatted my computer and started installing my old drivers and other softwares.
When I tried to install “Google Earth”, it sends me this error:
Hi!
Space is not the only requirement to install anything in your system. The major requirements are RAM and processor. Had you checked those.? These things are enough to install Google Earth in your system.
Sometimes, it is also not possible due to security reasons. So, check your anti-virus and try to install Google Earth after disabling your anti-virus. You should also update your windows, specially your browser.
In error message, it was also written the given version of Google Earth. Try to install another version of Google Earth. It will work.
If the problem happens when you try to install Google Earth through the Google Updater, try installing Google Earth separately. To do so, download the latest version directly from http://dl.google.com/earth/client/current/GoogleEarthWin.exe
If installing Earth directly didn't resolve the issue, it's likely that the problem you're experiencing is related to Earth specifically. For these issues, see the Installing and Uninstalling Google Earth article in the Google Earth Help Center.
From here you can get all the news & updates about Google Earth.
Good day,
This kind of problem is due to the incompatibility with your system hardware and software that you’ve installed.
Try to download another Google Earth compatible with Windows XP, 7 and Vista.
Thank you and good luck.
Shenna22
