Software to create msi batch how?
Hello I am a new user and need your help. I need to know software to create MSI batch how? Which software should I use to create MSI batch? Please help me with details including full installation process.
There are lots of software to choose from depending on what you need or useful for you. Batchrun, Create multiple from a List (Text File) Software 7.0, Batch File Creator 1.1, etc. You can go look for Software to see what you actually need. There is also WinInstall LE free mostly on Server 2k CD. Install that on the server. Used a clean image, run the discovery from the network, Install and configure the software, rerun the discovery to complete the snapshot or if you want to execute the BAT file from MSI installation you have to make a custom action.
