Software that Create PDF files
Dear Adrian,
There are many software to create PDF files. You better go to this site for free download www.dopdf.com. I am working with dopdf very often for making pdf files of word, excel and powerpoint. It will install as like as a printer in your computer. You will find it your word, excel and powerpoint print menu. When you want to make pdf file just go to your print option. In the print section while you print at the beginning there is a box where your printer name shows. Besides there is a drop down list. When you click drop down list you will find dopdf then just select dopdf and make pdf files as like as print a file.
I hope you will enjoy to work with dopdf.
If you simply need a program that can create PDF files then the site below will surely help you. And if you need to do a different job besides creating a PDF file, you can find the tools you need from A-PDF. You may visit A-PDF – Affordable PDF Tools for your PDF needs. Some of the PDF tools they offer are listed below.
PDF Merger and Splitter
PDF Modifier
Just visit the site to learn all the products you can download.
