How do I create and edit fillable PDF forms then view in Mac Preview?Â
I used to have a PC with Adobe in which I do this.Â
I am now a Mac user, and I have an iMac with quad core i5 3.4 GHz and OSx Mountain Lion.Â
I need software to create PDF forms Mac.Â
Software to create PDF forms Mac OSx lion
Hi Harris,
If you are a Mac user then you don't have to install any other software than Adobe reader.Â
Here are steps for you:
1. From application, select File > Print.
2. Now choose the PDF menu from bottom-left of the print dialog. Select Save as PDF.
Here is a screenshot.
3. Select name you want to give to a PDF file and then choose a location to save the PDF. This will help you.
Edward.
Hi Harries!Â
You agree with me that we are sometimes tensed about how to create edit able PDF forms.
It’s sometimes become very necessary for our daily life.
Ok, I am trying to describe it very easily as image tutorial as follows flow:
1. Go to File > Print > Printer.
2. Tools Menu > Forms > Create.
3. Selective use an existing file > Next.
4. Select use the current document > Next.
5. Edit as your desired target.
6. Finally, press "Edit" button to complete edit.
Hopefully, it’s now clear to you. Best of luck!
