I am planning to give something artistic, visual, beautiful and appealing gift for my project manager. I need a good software that can make this project and matches on the list of my ideals.
Is there someone who has the brightest and creative idea or suggestion on the kind of software that I am going to use in order to come up with such a nice gift for my manager?
Software for creative, artistic, visual, and beautiful projects
If it is a presentation that you are trying to make that with not doubt I will suggest that you use the Ms PowerPoint program. You will need to install the latest version of ms office that has the latest version of Ms PowerPoint and that is ms office 2010. The features that you will be able to use are:
You will be able to embed videos and presentation to be part of the presentation as you want.
You can use powerful animations and transitions that are better in Ms PowerPoint 2010.
You can control the presentation using a remote, and therefore no need to scroll through it using the keyboard keys.
-Experttechyv
