breant
Posted on - 11/03/2011
Hello!
I am searching for software that directs various websites to various network devices.
My phone is tethered to my computer for Facebook at work. Facebook is blocked on the internet at work.
I need to direct Facebook via my phone but have everything else via the network at the office.
I need this done minus having network device connected or disconnected.Â
Please help me.
Jackman
Software that directs various websites to various network devices
I would suggest you try to log in using a proxy server this will enable you go past blocked websites and surf the net. Use software that can bypass blocked sites for example ultrasurf and Freegate. All you need to do is to save one file on a USB stick then when you want to surf just plug in and surf. You need no additional installations to access your sites.
Set up a remote connection between your home computer and the computer using programs like LogMeln's Java viewer you need the IP address of your computer to set up the address. You will then see your home screen from your present computer then you can use your home computer from the computer that you are using.
