A software for easy convert from excel to PDF.
Hello Experts,
A software for easy convert from excel to PDF. I got 50 excel files that needs to be converted into a PDF format and I need it as soon as possible. I am just thinking if there is a software that will give me an easy way or fast way to convert files from excel to PDF.
I hope you can help me guys.
Thank you.
Best Answer by Taylor Adrit
Answered By 0 points N/A #186718
Do you have an Adobe Reader software installed on your computer?
If you have:
  1. Your file has opened.
  2. Click the Office Button. Click Save As then selects PDF or XPS.
You'll have your document in PDF right away.
But if don't have the Adobe Reader software, you can download it here:
Or try online converters:
Answered By 0 points N/A #186720
Hi Jeffrey,
There is a software who can convert excel to PDF. I will share you the website to download. In this site you will learn the step on how to convert excel to PDF. Just follow the steps carefully. Here is the URL:
The name itself answers your question. God bless.
Hope it can help.
Thank You.
Answered By 0 points N/A #186722
To free convert from excel to PDF format. Use this site:
Submit your source excel file here, by choosing the file to be converted from your computer. And provide your email address. The converted PDF file will be emailed to you after conversion.
Answered By 60 points N/A #186724
Hi Jeffrey,
I have read your concern and I have found a lot of answers in the internet. You can directly convert it in the MS Excel Application or else use some other software to do it for you. You must do what makes you more comfortable. I can suggest you go to some forums so that you will have a lot of ideas in doing that (by reading some post, you can understand more about your concern).
I can suggest you some good forums, which are listed below:
Answered By 0 points N/A #186717
Hi Jeffrey,
Good day and Conversion of an excel file to PDF is not as so easy because no such software exists for now even if exists that may not be working fine as the file after conversion may get crashes so there is an alternative.
You transfer those excel files to word document as the conversion from word to PDF is so easy as we can even convert online itself and you will get definitely accurate results as the document is not protected and for now as you need an emergency solution this is the best way for conversion.
Another way is to just backup the file from the computer so that it may gain its originality as backup's will always be succeeded for big data like HDD and others so this is just a minor one so try to backup the file so that your issue may be resolved.
Answered By 75 points N/A #186725
You can easily convert excel file to PDF. I am sending you the web link through which you can convert your excel file to PDF:
1. Click on the URL: https://www.sodapdf.com/word-to-pdf/
2. Then In the Input File: Choose your file.
3. Then click on the Convert Document Tab.
4. After word they will ask you to save your converted file to your PC. Just Save it.
Your file is converted.
Thanks
Pearlservice Group
