sam swann
410 points
Posted on - 06/04/2011
Hi to all, I am here today with a new problem. I am doing some kind of odd jobs. I need a calendar of some 500 years for my job to be done. I try to collect this type of calendar. But I am failed to get this type of software. Can anyone provide here this type of software or any link for this kind of software? Is there any other way to generate this kind of calendar? Please share.
hansi
A software for enhanced calendar
Normally calendars are found of 100 years or 150 years.
As for example in windows XP, there is calendar of 120 years or so. I do not know what your need is.
But you can find such calendar software in Google very easily.
I do not know why you do not get from Google or some other search engine.
Google is the most enriched database of the current world.
But you need to increase your search skills for getting your desired material.
It is too much important to put the appropriate for searching. I do not have this kind of software.
I actually do not face such need so far. But I do the search for you. And now see what I got.
Google gave me links to get this kind of software. I give you such a link here.
This link gives you your desired software very easily. For this I share this link.
Here is the link:Â I hope this is the thing that you needed.
This will help you.
Thank you.
