Jedei Powel
30 points
Posted on - 05/13/2012
Every time I try to put Intel Utmost (a) Artwork Motorist on an Apple 82845G art which has an AGP online video greeting card installed, this specific error appears.
Please help!
Severe
A software occurred. Please report this to Technical Support: Cannot install Intel® graphics driver on
current graphics device.
alatagan
Software Error: Cannot Install Intel Graphics Driver on Current Graphics Device
Hi there, well apparently you are trying to install the Intel Extreme Graphics Driver on an Intel 82845G graphics controller-based system that has an AGP video card installed. the error occurred because when you are trying to install the new graphics driver it is actually not intended or it's not compatible with the AGP video card installed on your unit. So sad to say but you cannot be able to install the new graphics driver on Intel 82845G since these chip sets does not feature integrated graphics.
Support for Intel 82845G Graphics Controller
This is a wrong installation there are different graphics card in the market with different chipset, this causes errors to the computer it's good that you must check the graphics card name and number and check the original drivers for your computer and make sure the software you're installing are compatible in your operating system.
