janajacobb
Posted on - 10/31/2012
Hi guys,
I tried to reboot my machine with Windows XP Home and received the error message: "Software error load needed Dlls for kernel". What does it mean? I searched several sites but no such problem. If you have any idea for the issue, please help me to get a remedy.
Thanks in advance.
Dear Janajacobb,
Run a full scan with your antivirus or Restore your system to previous date before you encounter the error using System Restore function.Â
Update your drivers specially your Video Card to the latest.Â
Or you can install windows updates; some updates could have a kernel.dll update and could fix the error.Â
If the problem still persists, try repairing your windows installation or your DirectX 9 for window XP operating system.Â
Your last option is to perform a clean installation with windows Operating System if the following solution does not solve the problem.
hope this helps.
