Software to find the location of my theft laptop
Hi everyone
What are the softwares used to find out the location of my theft laptop? How to use the softwares to find  the missing laptop?
thanks
Hi everyone
thanks
There are various software to locate the stolen laptop or mobile phones.
Of them some popular ones are Prey, LaptopCop, Laptopsentry etc.
To find out missing laptop: 1. First you have to check for the exact location of your laptop. For this Check on the Wifi look up of the software to know the exact geological location of your laptop.
2.Then check the nearby hotspots against a database, typically Google, Skyhooks to find out where the laptop is.
3. Searching with an IP address can certainly give a rough location, but a far miles away from the exact one.
Caringal Cheong
Hi Daniel,
There is one recovery application called GadgetTrack, which offers wi-fi positioning and webcam support to snap a photo of the thief.
It provides anti-theft software for laptops, including Windows and Mac.
Another theft recovery application is Norton Anti-Theft. Norton Anti-Theft helps you instantly locate and lock down stolen laptops, Smartphone, and tablets.
Simply go to the Norton Anti-Theft site from any Web browser to see your device's location
on a map, immediately lock it down, and even discover who has it.
The most popular laptop retrieval software may be Absolute Software's Computrace LoJack
for Laptops, tracks and delete data in your laptop using GPS/Wi-Fi.
Some location based tracking services are LocateMyLaptop.com and Loki.com.
Hope this helps!
