Software to find spam in Oracle
I want my Oracle application just like an outlook. I want to restrict some spam entries on the spot. It is not so hard but I forget the name of the software to find spam. What is the name of this software?
It is very essential to have a tool to block spam. There are many softwares to block spam. You have to choose the software according to your requirements. The default number of programs that can be installed to check spam is 8. Follow the steps below:
1. Select the program that you want to install to block spam.
2. Install the program and run it. Make sure all the required files are loaded.
3. You have to indicate what type of messages have to be blocked and what should not be blocked.
4. Set the priorities to the messages and specify which messages to block as spam.
The most commonly used tool is Oracle Right Now tune ups.
