Software to find spam to strict contents
Spam recovery software has been stopped working to find spam contents. What causes may involve for this problem?
Hi Alex,
It would have been easier if you mentioned which spam recovery software you are using. In general there may be multiple reasons for the software to stop working. As the software is used to find spam it may have several restrictions such as the anti virus. Try the following steps:
1. Go to control panel on your computer and click on uninstall a program.
2. Select the spam recovery software and click uninstall.
3. Now reinstall the software on your computer and restart the computer.
4. Now try to run the software. It should be running now.
If it is still not running then you could try another software. One good spam recovery software is Anti SPAM Guard 4.
You can get it here – http://www.anti-spam-software.com/.
Every time a software starts showing signs of problems or maybe totally stopped working, there are several reasons why this happens. One is data corruption. This can be due to errors in the system which affected the system files of your software. Another is improper use of your computer. Improperly using the computer involves behavior like not shutting down the CPU properly, shutting down the computer without closing running programs, and so on. These activities can damage open files.
This problem can easily be fixed by simply re-installing the software or upgrading it to the latest version whichever you choose. Checking only the computer using the scandisk or any disk utility applications without re-installing the software will not help solve the problem. You can use disk utility programs to check your drive but you still need to re-install the software to make sure that all its files are restored. But you can always check if the anti spam software is already working after using disk utility tools.
At first, I want to thank you all guys for your impressive comments. Sometimes I visit the Techyv.com at a pinch. As a rule when I faced any problem I am at a loss what to do. I moved heaven and earth to solve this problem but all my deeds become vain. But suddenly, my mind flashed back that I can fall back upon the Techyv experts and by analyzing this comments I have learned the root cause of my problem which I was not aware of this matter. Thanks guys for helping me a difficult task to hammer an idea into my head, as a result your solution makes the error disappeared for good. You are providing a great solution and a recovery software to solve my problem. Thanks again guys, in fact I appreciate your advice.
