A software to format and repair hard disk
Hi there! Do you know some software to format and repair hard disk? I need it for my laptop to remove a Trojan in my hard drive. Thank you very much!
You will need a bootable image disk of any operating system maybe of windows or even Ubuntu.
You will need to reboot your computer from the DVD drive with the image disk in it . Then select the drive you want to format and format it.
But you don't have to format your computer and loose all your data. You can system restore to a point when your computer was still fine without the Trojan. Also try using an anti virus.
Thanks
Amos Marie
Hello Harry
Format through windows is better but through external software is also better.I am giving you best hdd repair software application which i have also experienced in. Screwdrive is the best among all because it is easy to install and take less space to install.It is user friendly and easy to use.The second one is formatting tool is as follows.
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
This is also easy to use and format the drive in all format like FAT32,FAT etc.
Hope this work for you.
Thanx
