Software to free remove glasses from a picture
Where can I download software to free remove glasses from a picture? I need to create blinking eyes on the picture.
You can go to this site http://html5maker.com/#/ to download the akvis multibrush. There are some other sites where you can download the trial version of this software like akvis.com/en/multibrush/download-brush-tools.php. You can also go to link It is a photo editor which makes your photo retouching job easier. You can use the tool to remove glasses as well as the other flaws from the photo.
Best regards.
Hi Joan d vogt,
There are no software remove glasses on your picture. All graphic software just gives you tools and you have to do by yourself. How good your picture look depends on how expert you are. I can suggest some graphic software: Photoshop, GIMP, PhotoPlus…
If you use Photoshop, use combination of clone stamp tool, patch tool and healing brush tool to remove glasses.
If you want to create blinking eyes, download more brush from the Internet.
Hope this helps
