A software for greek language for autocad 2009?
Hello Experts,
A software for greek language for autocad 2009? Is there a possible software for autocad plug in that will change English language to greek? My friend is greek engineer and needs to borrow my autocad application for some designing purposes. I hope you can give me a solution for this.
Thank you.
Best Answer by Ancheta Nelson
Answered By 60 points N/A #179945
Hi Isabella Barry,
I think the there's a version of AutoCad in Greek language. I've searched the internet and Google to find the best solution with your problem. I have attached a link of downloadable Autocad in a Greek Language with Screenshots.
Autocad 2009: Greek Language
Hope that it would help you.
Thanks and more powers.
Answered By 0 points N/A #179946
Hello Isabella Barry,
Assist you in this problem is a pleasure for me.
Working AutoCAD in English and borrow applications to your Greek friend is not impossible with Babylon 9 Software. It is coming with AutoCAD plug-ins so your problem is solved. If telling you something about Babylon 9, it is the most popular translating Software ever for professional people. I recommend you to download it from http://translation.babylon-software.com/english/to-greek/Autocad/ and it is free. Also you will be provided with 24/7 Human Translation service to keep your mind freely.
I am sure this is the best solution for the language problem between you and the friend.
Thank you.
