aijaz
10 points
Posted on - 07/24/2011
Hello guys,
I recently bought a desktop computer (used) with a Viglen motherboard. After installing the window, I couldn't find the drivers on the internet because I was unable to locate the model of my PC's motherboard. Can you please tell me that is there any software which can show us the information of the motherboard including name and model?
Jayar31
Software to Identify the Motherboard Brand and Model
Hi Aijaz,
Here are the features and information about the Motherboard name: Viglen
Feature Summary
The Vig590M is based on the Intel® 945GC & ICH7/ICH7R chipsets for optimal
System efficiency. Designed to fit the advanced Intel® Core 2 Duo/Pentium/Celeron
LGA775 processor, the Vig590M delivers a high performance and professional
Desktop platform solution.
The motherboard features:
Form factor:
• Micro ATX Form Factor: 243mm by 230mm
Processor:
• Intel® Core2 Duo
• 1333Mhz Front Side Bus
• Socket 775 connector.
Main memory:
• Two 240 pin DDR2 DIMM sockets.
• Support for up to 4GB of DDR2 DIMM memory.
Chipset
• 945GC
• Up to 1333MHz Front Side Bus (FSB)
• Support for 400/533/667MHz DDR RAM
• Advanced System Power Management features
• Integrated Super I/O Controller
• 3 flexible audio jacks, HD Audio capable
Audio
HD (High Definition) Audio compatible audio subsystem
LAN
Realtek 10/100/1000Mb/s Mbit/Sec Platform LAN Connect (PLC) device
Peripheral Interfaces
• Support for two internal Universal Serial Bus (USB) ports and four external
• One serial port
• One parallel port
• Two IDE interfaces with Ultra DMA 33, ATA66/100/133 support.
• Four SATA interfaces.
• One diskette drive interface
• PS/2 keyboard and mouse ports
Expansion Capabilities
V1.0 VIG590M Motherboard Manual 6• Four PCI bus add-in card connectors
Instantly Available PC
• Suspend to RAM support
• Wake on PS/2 keyboard, Mouse and USB ports
Microprocessor
The motherboard supports a single Pentium 4 processor with HT technology. The Processor’s VIG pins automatically program the voltage regulator on the Motherboard to the required processor voltage. In addition, the front side bus speed Is automatically selected. The motherboard currently supports processors that run Internally up to 3.8GHz and have a 1MB second-level cache running at full CPU
Speed. The processor implements MMX ™ technology and maintains full backward Compatibility with the 8086, 80286, Intel386 ™, Intel486 ™, Pentium, Pentium Pro, Pentium II & Pentium III processors. The processor’s numeric coprocessor Significantly increases the speed of floating-point operations and complies with ANSI/IEEE standard 754-1985.
Microprocessor Packaging
The Pentium 4 processor comes in a LGA package that connects to the motherboard through a socket 775 connector. The package consists of:
• Processor card including the processor core and the second-level cache, burst pipelined synchronous static RAM (BSRAM) and tag RAM.
• Thermal plate.
Hi Aijaz,
You can make use of CPU-Z to find out detailed information regarding your PC's hardware, not just the brand and model of the motherboard, but any graphics card as well, in case you need drivers for those too. You can download CPU-Z via this URL: https://www.cpuid.com/softwares/cpu-z.html. Just click the download link in the panel on the right side, labelled "1.58 setup, English".
After installing CPU-Z, run it. The first tab shows you detailed information regarding your CPU, the second about your cache. The motherboard information you need will be on the third tab. Fourth and fifth tabs will show you detailed information regarding your RAM, and sixth tab about your graphics.
I hope you this will be able to find all the information you need to get your drivers.
Kale
divren23
I found a site which I think it can help you a lot. Here it is:
https://www.viglen.co.uk/viglen/support/Ftp/motherboards.aspx/?GUID=.
Choose which model you have, click it and download it. Some files are on .Zip so, you still have to extract it. Make sure you successfully installed your Operating System before installing the drivers.
I hope this would help you a lot.
If you bought a used computer with a Viglen motherboard, you can always find the model number including the website of its manufacturer printed on the motherboard itself. Shut down your computer and open the CPU case. Check the prints on the motherboard, you should find the model number in there like without quotes “Viglen Vig730M” or just “Vig730M”.
Once you located the model number, take note of the model number then head down to Viglen Limited Support Downloads/Drivers Motherboards and look for your motherboard. Once you located your motherboard, download the complete drivers set and save them on your computer so that next time if you need to install them again, you no longer need to download them because they are already on your hard drive.
Also, make sure to download the BIOS update so you can update your motherboard’s BIOS.
