Software iPhone recover erase contacts
I format my iPhone and lost my contacts data. What is the suitable software iphone recover erase contacts easily?
There is a solution for this. You can actually restore the contacts which are lost. For that you need to download the Wondershare Dr.Fone tool which will help you in recovering the contacts which are lost. You can search online to get the tool available. You can also download it from IPhone app center I guess I am not sure but try once.
You can also see the below link which has few more tools and clear explain of how to extract the things
http://www.funkykit.com/how-to/7898-how-to-extract-your-contacts-from-iphone-or-itunes-backup.html
Please let me know if you need any more help on this.
Samuel
Since our mobile phones are getting advanced and advanced, doing accidental mistakes like unknowingly deleting a contact from your phone’s contacts list can easily happen with just a simple press of a button or a slight tap on the screen. In that instance, the record is deleted in an instant. I’m not sure if it’s the same but in iPhone, deleted contacts don’t mean that it is completely deleted or permanently erased. You still have a hope because of the backups you created.
If this problem happens and you haven’t synchronized your handset with your computer yet, there is still a chance of recovering the deleted contacts using iTunes. Here’s how you can do it:
After that, you may now remove your Smartphone from your computer and then check the deleted contacts if they were restored.
