FREDDIE
200 points
Posted on - 05/30/2011
I have HP laptop. The machine specification is core i5, DM4 Pavilion 2.27, 1 GB Video, 4 GB ram and 500 GB hard disk. It has Genuine Windows 7 home premium (64 bit). I installed Avira antivirus program through the internet free. The problem is that the machine is responding very slowly and some of the applications are not executing properly.
I tried to open Corel Draw application, which first opens properly, and then hang for few seconds and stop the program. I cannot understand why this issue is happening in Laptop? Is this for the Avira application or for another application, is there anyone having similar information on this problem? Please help me to solve this.
Computer runs slow after installing Avira Anti Virus
I have read the issue that you have, if the problem exist right after installing the AVIRA protection on the computer so the issue is with that software. There is a possibility that the virus protection is not compatible or is having conflicts with other softwares on the computer. We can check if you have any other virus protection installed on the computer and have it uninstalled because you can only have 1 virus protection on the computer.
If you don't have any other protections on the computer so that means that we need to uninstall AVIRA. UNINSTALLING PROGRAMS ON THE COMPUTER – click 'start' – click 'control panel' – click 'programs' – click 'uninstall a program' – look for any other virus protection, if none are present, look for the AVIRA and click it – it will be highlighted in blue, click 'uninstall' at the top of the screen – wait for the software to be uninstalled and it will as you to restart the computer – restart computer and wait for it to turn on – check if the problem is fixed and if its fixed that means that the avira is the issue I will suggest installing the Microsoft pc security or the Microsoft security essentials as you virus protection cause I'm actually using it with my windows 7 computer too, and it works fine.
You can get the software to this website and install it on the computer (note: this protection only works if the computers operating system is genuine). – filehippo is the website – look for Microsoft pc security or ms security essentials and look for the windows 7 version of it -start installing it -once its done run a full scan, so it can check for the virus or spyware that might be on the computer.
HiÂ
Regarding on this issue there is another Techyv post which one also will be helpful for you to resolve this issue.
What are the main reason of slow PC?
