The software kde best clock choice
Hi everybody,
I need multifunctional desktop clock ,do you think kde best clock is the best software to download, I need your kind guidance?
Thank you in advance
Hi everybody,
I recommend you Vista Clock as your multifunctional desktop clock. It is a tiny clock that remains on your desktop and in the systray. It also presents other electrifying features, an excellent alarm clock for your desktop. Vista Clock has been experienced by Softonic, the most recent edition of Vista Clock with 30 antivirus engines and discovered that it’s virus-free software. This fully customizable clock allows you to dress up its looks with your own pictures.
Best regards,
Heather marie
For users who are new to KDE, it is a Linux application. So, if you want to install a KDE clock on your computer, you must be running Linux operating system. Since you are interested on clocks, try Minimal Clock 0.12. To install and use the clock on your desktop, you need to have KDE 4.x. See image.
Though KDE is a Linux application, you can also use it on Microsoft Windows using the KDE Windows Initiative. The KDE on Windows Initiative is a continuing project to dock KDE applications into Microsoft Windows. As of the moment, KDE Windows Initiative supports Windows XP, Windows Vista, and Windows 7.
If you want to try it on Windows, download and install the latest installer, KDEWIN Installer Latest. Since KDE Windows Initiative is an ongoing project, it is not yet in its final state. And because of this, there may be some KDE applications that are not suitable for constant or everyday use.
