Software to Keep Samsung Screen Share Feature Running Fast
I started to connect my PC with the screen share Samsung. However, the graphics seems to run slow. Is there a software to support faster screen share Samsung?
Good day,
There are many high speed screen share it can be through internet and local only. For high speed you can get Netop Vision Pro, it works at high speed and you can share PowerPoint your AutoCAD and Google earth with it. The entire Screen Share application now is compatible with any OS. Mikogo is another it can connect to cable channels and NCH Screen sharing. All of these Screen Sharing software are free.
Now without using software you can share screen too, using video out and video input wire and another is the multi connector computer output. So you can share to you Samsung screen LCD and video screens.Â
I think one of the problem of your screen sharing is the data transfer of videos and maybe they someway not compatible.
I hope these helped you.
