Software for LG 550 to install on my PC
Does LG550 mobile phone comes with a CD for installing into my computer?
I was trying to access it to my computer but I don’t have any disc with me.
Is this an error or do I need to buy another device individually?
Best Answer by Pheonix team
Answered By 5 points N/A #95140
Silvalillian
There are some software's which you can directly download from the websites, and a little detail of these software's is provided below:
1. Sprint PCS Connection Manager: This connection manager provides internet connectivity via Bluetooth or USB cable with windows XP, and also contains the device drivers. This can be downloaded:
2. There are multiple software's and utilities for LG 550 do visit the site:
3. LG Pc Suite: Before, going for this software, I suggest that you first read the reviews. This can be downloaded
4. LG 550 USB_Handset Manager: try this site:
5. Free download pc suite lg550:
PT
Answered By 10 points N/A #95141
You need to check that does your phone supports your computer connectivity. Is it a GPRS phone and supports Blue tooth or infrared connection. If it supports one form the given options then you can connect it to your computer.
You then need to install a Bluetooth device or a infra red device. If you want to connect it using a cable then you need to know what kind of cable you can use to connect your computer with your mobile.
Then if it supports a common wire then you can install a program to run this wire with your mobile phone. It is easy to install the software then if you know the type of cable.
One such program that supports many models of LG mobile is mobimb mobile phone connector. You need to install that software in your computer and your will be able to share your phone data over the computer.
Michal joran.
