Software to make the video tutorials
I want to upload tutorials on Algorithm Designing. I have seen many online tutorials on Udacity and Coursera. I want to make some videos like those tutorials but I don't know how to do it. How can I record my screen activities and record my voice simultaneously? Please give me suggestions to make those videos better.
Answered By 590495 points N/A #183366
If you want to create your own instructional video, there are many applications available on the internet that you can try. And of course, in order to record your voice on the video, you need to have a microphone for your computer. Or if you have a headset with a microphone in it, it can also be used to have your voice in the video.
One of the applications you can try is Ezvid. It is a screen recorder application that comes with a built-in video editor that lets you split your recordings and insert text in between 2 clips. Unfortunately, you cannot export the video you recorded but you can upload the video to YouTube from within the program. Visit Ezvid Screen Recorder to download.
Another application you can try is the BlueBerry FlashBack Express recorder. This application allows you to use your webcam to record yourself while recording everything that’s happening on your desktop. Once you are finished recording, the program creates an FBR file which you can edit using the packaged video editor.
You can use the program to resize or position your webcam box before exporting it. In case you didn’t enable your webcam, you can skip the video editor program and automatically export the video to AVI format. Visit BB FlashBack Express to download.
