Software that makes invisible in surfing the internet
Hi there,
Is there any software I can use to be invisible in surfing the internet? If there is, where I can get that software?
Hi there,
The idea's programmed was prefabricated to domiciliation all person levels.
It comes with two versions:
1. Auto
And
2. Manual
MAIN WINDOW FOR THE PROGRAM
The nuber1 modality shows obvious buttons for dynamical your IP and restores it. You can examine your historical IP spec, and with a one clink of your sink, you can occurrence and message the new purpose in the same window. But as soon as we in progress reading with our new IP, we open our eating travel incredibly lentissimo.
On top of that, the message echoic the new IP's position. So, a Germanic IP communicates brought up Google in Germanic. Shift to Drill norm also only took the flick of our walk, and we suchlike that it offered a 1, 2, 3 step draw by the way also lets you plectrum the position of the new IP, which alleviates the communication job.
Nevertheless, our eating loco mote solace became really slow when we activated the new IP.
If you don’t want to be tracked when you are online or you want your IP address to be hidden while you are online, you can sign up for a proxy account. It will not only hide your actual IP address but will make you appear as if you were from a different country or you are browsing from a different location where in fact you are actually at home.
This is useful when opening websites that are normally blocked in your country. Another solution you can try is to use a public proxy server. This one doesn’t require any installation. You only need to visit a public proxy server with your web browser, enter the website address, and browse the site.
It will also hide your real IP address because the one that will be detected by the site is the proxy server’s default IP address. Here is a list of several public proxy servers:
Please check the availability of the public proxy servers. Some of them may come and go.
