I am looking for a prominent search tool with more superior functionalities than windows search button supply.
I want to search files inside the zip file. Using filename exact words which am inside the zip file I wanting to retrieve that file. I need this type of word search zip files software which can run on any windows platform.
Please help my friends I am waiting.
Software needed word search zip files
Wassup Jeffrey,
I believe I can be able to help you in solving that problem. Indeed it is true that there are usually many files inside the zip file.
WinRAR can be the best instance of the software for searching for these word files in the zip files. If you don't have the WinRAR software yet, you can download it from the website.
Follow the prompts to install after the download.
In the Winrar window, go to the folder with the zip-files and navigate to 'Find'.
Leave * in the files names box and type the string you want to find.
Select 'Disks' and 'Folders'.
Type 'ZIP' under 'Archive types' box.
It will find the zip files.
I hope this solves your query.
If you are looking for a search tool that is able to search within ZIP files (*.zip), try using FreeCommander. It is a file manager similar to Salamander and Total Commander. Like Windows Explorer, FreeCommander can perform a search on the entire hard drive plus the ability to search within ZIP files.
With FreeCommander, you can perform search within ZIP files for terms like file names, text content, and apply filters like timestamp, file size, and file attributes (archive, read-only, directory, hidden, system, compressed, encrypted, and reparse point). I use this on my computer and it is way better than Windows Explorer when searching for items. To try this, download the latest FreeCommander XE.
It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit.
