kim kim
Posted on - 12/17/2012
Hi guys,
There is something wrong with my flash drive. I cannot format it by using windows. I want to find other program for format flash drive. Please tell where I can download program like that.
Thanks
Software or Program for Formatting Flash Drive
Hi Mr. Kim,
Please follow the below steps in order to format your flash drive.
1. Go to the start button-all programs-accessories-command prompt.
2. Right click on command prompt and click on run as administrator.
3. In the command prompt type format F: (if your flash drive has been connected to your system and the drive letter shows F else put the drive letter that displays your system).
4. Now it will prompt for yes or no.
5. Put y and hit enter and wait.
To format your flash drive. Just double click on my computer. It will show you the drives of your hard disk and Flash drive also. 1. Right click on your flash drive and then click on format.
2. It will open a window.
3. In Allocation unit select Default Allocation size.
4. Click on quick format check box and press enter or click on format.
Watch this tutorial its work the same way for flash drive also.
TUTORIAL VIDEO
If you want a software to format your flash drive. I will suggest you HP USB DISK STORAGE FORMAT TOOL because it is compact and efficient with the Volume Label, File System and device for Format option. It has also ability to make bootable dos startup disk. It can quickly and thoroughly format your flash drive.
