In my laptop, there is a built-in radio FM player and when I want to listen to a radio broadcast I just need to open NXP FM tuner application .
Can I record radio broadcasting?
Because there is no recording feature in that app.
What software do I need?
Software to record radio broadcasting
Hey,
Have you tried jet audio?
It is one of the best audio applications that you can have in your laptop.
Just set it up and hit the record button and there you are recording your favorite show.
Just Google jetaudio, download and enjoy.
Ping if you need more details.
You can select any software that records the voice and then you can do this easily but you first need to choose your options to the computer voice and then it will directly record form your computer. Select wave out form you recording settings and make sure you have enough level of voice set to record to your PC.
Now you require software which records voice and just click on record it will record form your FM radio voice and it works fine. You can use jet audio or a window recorder is also available for this purpose and you can select one as per your requirements.
Once you have configured all the things then you will be able to solve your problem.
