noah jones
Posted on - 11/26/2011
I am doing my homework for almost 3 days now. Upon opening, I accidentally hit Shift+Del and deleted my homework. I could not find it anywhere even on recycle bin. I am searching now for software that can recover my deleted homework. Can someone provide an answer? Thanks.
SARA U
10 points
Software for Recovering Deleted Files
Try to download the Advanced System Care, just visit this site: http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html
After you download the application just install that to your system then just right click the icon of the Recycle Bin then select the undelete and just follow the instruction from the I0bit undelete menu.
Just simply try to download the Error repair Tools, just visit this site: http://www.xp-vista.com/
Just simply install that to your computer, after installing the software then just restart your computer and try to scan the system or maybe the software, and just simply repair the found errors to your system. I recommend scan your system if it’s infected a viruses and then spyware.
Ben
