Software to remove duplicate files registration code
Hi! I want to get a software that remove duplicate files registration code.
I don’t know whether there’s such software.
Let me know, it will be a great help.
Thanks guys, in advance.
Hi Steven,
I hope this helps you.
Pamela Conley
Hello Steven
I have had this problem myself. Mine had been cause by a virus, that automatically duplicated every .exe file in My Computer. I don't know if your problem is similar, or you just know that you have lots of duplicate files and want to clean them.
However, let me tell you, it is not easy finding an appropriate software in order for you to clean up your PC.
The best one and also the one I have used Duplicate Cleaner. Click on the link, download and install it. Start the program and run a search with it. It is very easy to use and gets the job done for sure.
Another software for you, is Easy Duplicate Finder. Check it down at the link below.
I hope you will find this information useful.
Randolph
HiÂ
There is another Techyv post which is also addressed about this topic. Pay a visit that page to get more helpful information according to your question.Â
