Software for repairing corrupted and damaged ISO file
Hello friends,
What are those software for repair iso files? My employer is having a problem with his iso files, he told me yesterday that those files were corrupted and ordered me to find a way to recover or repair the files. Can you give me an idea? I need to solve this problem as soon as possible.
Thanks and Regards,
Trevor John.
Answered By 0 points N/A #187203
You can use the program called IsoBuster. All you have to do is install the program and run it. Once running, open your Iso file using the IsoBuster. Choose extract and save them to your computer. It is really easy to use. It is very user friendly and it works fast and accurately. You can download it at https://www.isobuster.com/
