Software for Repairing Xvid Movie File when it is Choppy and Stuttering
I'm looking for a software that can repair mov xvid file like when it is frozen or becomes choppy. Can you suggest a free software that can do this?
A video that sometimes suddenly freezes or becomes choppy is a result of an incompletely converted video. Check if the video you have is a converted version and has its original file. If the video has an original file then check if the original video is clean and doesn’t show any sign of sudden freezing and choppiness. If you find some discrepancies between the two then you just simply need to convert the original file to the format you are using right now.
If you want some handy video tools you might need in fixing your video’s problem, you may try visiting ImToo Software Studio.
Notifications
