Software required for making videos and editing
I need to know a easy good video editing software.
There are many online software free downloadable but when I download them either they are trial version  or they are had to word with.
I need an easy software for video editing which will be free as well.
Should someone know of any software matching my requirements kindly inform me about it.
Howel Dinh
Best Answer by Valbuena jane
Answered By 5 points N/A #110494
Here are few video editing software's.
I have arranged them on the basis of  Video Capture/Playback , Ease of Use ,Editing Tools, Export/Production , Editing Effects/Transitions ,Audio & Photo Editing
1) CyberLink PowerDirector
2) Corel VideoStudio Pro X5
3) Adobe Premiere Elements,
4) MAGIX Movie Edit Pro,
5) Roxio Creator,
6) VideoPad,
7) Pinnacle Studio HD,
8) Sony Vegas Movie Studio Platinum,
9) Roxio Video Lab,
10) MoviePlus
Cyberlink has best Video Capture/Playback , Ease of Use ,Editing Tools, Export/Production , Editing Effects/Transitions
 Audio & Photo Editing .
So I would recommend it for you.
Answered By 0 points N/A #110496
I would recommend that you use Cyber Link Power Director video editing software shown below.
To begin with, it is free and has an excellent video capture and playback. It is also very easy to use with good editing tools, good disc creation, excellent editing effect and transition. It is easy to download title templates using it and download frames.
It has timeline, storyboard, and split/ divide scenes, trim scenes, add text to video, video stabilizer, zoom in and out video editing tools. It also facilitates importing audio, mixing audio and changing image properties.  It supports Windows Vista, Windows XP, Windows 7, Mac operating systems. It also has tutorials, phone support and paper manual to facilitate usage.
Another good alternative would be Movie Plus X5 video editing software.
It is easy to use and has good editing effects and transitions. It has video editing tools for timeline, storyboard, split/divide scenes, multi trim scenes and draw on video capability. It is easy to import audio using it and also cropping, resizing and editing images. In disc creation, you can create custom menus, divide into chapters, download menu templates or even add music to menu.
Martin Mairu.
