Software sap tweak l schen similar
Can i get another software which is similar to sap tweak l schen. I like it but then the interface is not very good. So, I want to see softwares that are similar to it.
Hi.
sap tweak is a GUI family software. And surly you can find many other software like SAP tweak.
The most nearest software to SAP Tweak is SAS GUI.
Aside that u can try GUI STUDIO too.
And depending on your need you can check on this link.
Top 7 GUI software of the year.
https://decisionstats.com/2010/05/07/the-top-statistical-softwares-gui/
This program has been reported to be unavailable on a regular basis.
This implies that we are unable provide universally aplicable download links, relevant version information, or any further updates.
SAP Tweak GUI is developed by SAP AG and is used by 1530 users of software informer.The name of the program executable file is TweakGUI.exe.This particular product is not fit to be reviewed by informers.
