Software suggestion for MP4 video converter
Hello everyone. Please suggest any free program that can convert MP4 videos into Ipad friendly format. It should not be free trial versions.
Hello Clifford,
There are so may software which you can use to convert MP4 videos into IPad friendly format.
I will provide links below which you can use to see the choices. All of them are good, proven and tested.
Now you can choose any of these sites.
Enjoy! and Good luck!
Zorian
Dear Clifford,
Option I –
I would suggest you download a paid program called Video Convertor Pro (See Image below) for Mac costing $39 supporting OS Mountain Lion.
The link to download is – http://www.effectmatrix.com/total-video-converter/guide/videos-to-ipad.htm.
Follow these steps to convert your files –
1. Install Video Convertor Pro
2. Drag and drop MP4 video files to Video Convertor Pro
3. Select iPad option,
4. Click “Start” button available on the extreme right on the bottom of Video Convertor Pro.
See the magic!
Option II –
Else if you want to spend a little more you can simply purchase iPad 4 in which you don’t need to convert MP4 files.
