A software like tera file for Mac users please
Hello techyv.com!
I was a Windows user before I've bought this MAC laptop. Now I was trying to copy my files from my Windows to MAC but it was quite annoying because it takes so much time to copy. Now I've downloaded tera file, but it won't work on my MAC laptop. So is there a tera file like software for mac? Something that will fasten my copying and discarding bad files. Thanks!
Best Answer by oliverpowell
Answered By 40 points N/A #153911
Its always not easy to transfer file between two great rival, Windows and Apple Mac, Operating System. There are quite a few software available on the internet that can make your task easy,
However I have arranged a useful for you, Which will teach you essential way to transfer the data from windows to mac OS
How To Easily Share Files Between Mac Windows Computersax
Moving from Windows to Mac
Answered By 50 points N/A #153912
There are many ways to transfer data (files) from a PC to a Mac, including:
  • using the Migration Assistant built into OS X Lion and later
  • using the "PC Data Transfer Service" at Apple Retail Stores and Apple Specialists
  • using a portable hard drive or storage device
  • using a CD or DVD burner
  • using other portable media
  • using a shared file server
  • using email
  • using a direct Ethernet connection
  • installing the PC's hard drive in the Mac, if compatible
