Software Throws Application Error Event 1000
I am trying to open my application but it continuously throws the error I don’t know what to do so I want to know, What is application error event 1000? How to fix application event 1000?
when the application crashed then the application error event 1000 occurs it is included in the event viewer log. You can’t open the application it unexpectedly closed.
Steps to fix application error event 1000:
Method 1: Using the command prompt
1. Click on the start button and type cmd.
2. Now right-click on the command prompt and click on Run as Administrator.
3. Now type the command: sfc /scannow and press Enter.
4. The command scans all the corrupted files and restores it.
Method 2:
1. First press the Windows + R and then on the run window type the msconfig.
2. On the General tab click on the Selective startup.
3. Now check the box of Load System Service and Use original boot configuration.
4. Uncheck the box of Load step item.
5. Then open the services tab and check the box of the Hide all Microsoft services.
6. Now click on Disable all button and then click on apply and ok.
7. The on the dialogue box click on the restart button.
Notifications
