Software to transfer data from bb offline
Some important data have to transfer to my iPhone from my BB which has been switched off due to low battery. Which software will be best to transfer data from BB offline?
I see that you want to transfer data from blackberry to an iPhone. There is an app designed for this purpose.
The app is called Berrymover. It is available on the apple store. It helps you to transfer all data from your blackberry to the iPhone. You just have to provide a few details of your blackberry and then you can transfer all your data to the iPhone.
The Berrymover is a very effective app and transfers all your data to the iPhone. Your calendars, tasks, reminders, etc. can be transferred to iPhone. You can also transfer the backups from bb.
Another option is to use the Blackberry desktop manager. It will be on the cd that you get when you buy the phone.
Hope this information helps you.
