Software uninstall utility is missing
Dear Techyv Friends,
I am using Windows XP in my system, I need to know about how to uninstall a Software or Program when the software uninstall utility is missing or removed.
Please advise a good method that will uninstall and remove all the related files.
Thanks in Advance,
Arthur W Adams
Answered By 0 points N/A #128861
There are third party utilities which are very good, one of these is the Ccleaner.
In addition to uninstalling, the utility has other features like start-up editor, registry cleaner, temporary files cleaner and empty space eraser.
Setting up the application is easy once you download, another good utility is Uninstall Plus, but this is only functional for 15 days after which you have to purchase it, Ccleaner is a freeware.
