Software update error – MacBook Pro
Hi TechyV buddies!
I am having some trouble updating my Mac Pro. It is almost two months now since I updated My Mac pro. It seems that all the updates needed are downloaded already, however, when I start to install them. I always encounter n error. Every time I install the updates and restart it for updates to take effect, an error message appears, saying this:
“Unexpected error”
It tells something about my unsuccessful updates. This has been running for two months already which means that my updates have increased and it continuous to grow bigger if not solved. Can you help me configure the problem of my Mac Pro? Thank you!
