Hi, I am having a problem in my Nokia n70. I was trying to update the software using ovi suite in my computer. But after a few time the update stops and showing me ERROR 12052.
I reinstalled the ovi suite but the problem remained as same. Now please give me some hints about how to fix this. Thanks
Software update failed by Ovi suite
If you are using a USB cable to connect your N70 to your computer, check your cable if it’s not damaged or something.
If your attempt to update your phone’s software failed on the current port, try transferring your connection to the other available USB ports on your CPU and then try again.
Before updating your phone, check your device’s signal reception. It is possible that the reason why your attempt to update your phone’s software fails is because of a very low signal.
If your phone has a very low signal reception, the download for the update might get interrupted and normally if you are doing the update by phone, an interruption may result in automatically aborting the whole operation. And then you receive the error message.
