Software updater for bb offline
Black Berry is a different mobile due to its features and functions, even software. How can I get an updater that can update bb offline regularly?
Good day !
I believe there is no software that can update BlackBerry Mobiles offline regularly. The main reason is that it needs internet connection so that it can search the appropriate update if ever there is available. Although another way is by installing the BlackBerry User Tools CD which is included in your BlackBerry Box so that you can check for updates. It also allows you to sync your files and do more stuffs for your phone. Hope it helps!
I’m confused with updating your BlackBerry phone offline. I think what you mean by that is to update your phone using the OTA or over-the-air which doesn’t use a computer that is connected to the internet and only uses the cellular network to update the phone’s software. This is a more convenient way of updating your handset without the hassle of connecting your phone to the computer and updating it via the internet.
But sometimes, due to network congestion, updating the phone via OTA is not suitable. An alternative to OTA is using a web browser and updating your phone using the internet. To try this method, you need to have Microsoft Windows Internet Explorer 5.5 or higher or Mozilla Firefox. For Mozilla Firefox, download the latest version from Firefox Free Download.
For Microsoft Windows Internet Explorer, visit Upgrade Internet Explorer to update your current browser. Once you are using the latest web browser, for users with BlackBerry 7 and earlier operating systems, visit BlackBerry 7 Software Updates. For users with BlackBerry 10, visit BlackBerry 10 Software Updates. Once on the site, check your browser for a message asking you to run an add-on.
Click and run the add-on. After doing this, you should see the button “Check for Updates” on the page. Click on it to check for an update. Before doing this, make sure your BlackBerry phone is already connected to your computer.
Hi
According to your question there is another Techyv post which one will be also helpful for you.
Notifications
