Software updates with Update Freezer
I have looking for such a software for days that can control automatic software updates and have come to know about the Update Freezer.
Does anyone know about the controlling procedure with this?
Update freezer is a tool which can be used to see the updates about the software's installed in your system. This can be launched by just running the command line utility UpdateFreezer.cmd.
Which will show you all the updates of latest software's that are installed in your system. This will also allow us to disable the updates temporarily. It can be run even from USB stick where it will show you directly whether you require updates or not.Â
This tool can be installed in any flavors of windows.
But, I am not sure whether it will work for windows 8 or not.
Just try if you have downloaded that windows 8 OS.
Update Freezer is a useful handy utility which creates very easy access to control most of your very important software update settings. You just have to start Update Freezer and understand the current update settings for your Windows, Flash, Adobe, Google, IE, Firefox and other software.
You choose can when to update your favorite software or disable automatic updates momentarily until need to update them. Update Freezer generates your update procedures easy, by giving the update settings of all your applications into a single place. You can use these similar software too.
AutoUP
Patch My PC
Downloadcrew UpdateScanner
Secunia PSI 3
